Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > 4 Ohm 2 channel 150-200 Watt per chan...
Author Thread: 4 Ohm 2 channel 150-200 Watt per channel amp
Username: Afroopuff
Post Number: 332
Running a pair of CDT HD-62CU's
Any ideas? Price would be beauitufl around 200 or so
Username: Ctmike
Ct.
Post Number: 2644
ed nine.2x can be had for just a little over $200 with the forum discount. maybe a used xenon 2 channel.
Username: Afroopuff
Post Number: 338
Ive seen the link to the forum discount once before but I no longer have it....anyone that can inlighten me and save me a lil money and get me that code. It'd be awesome, thanks
Username: Ctmike
Ct.
Post Number: 2654
http://www.edesignaudio.com/edv2/index.php?cPath=90
Username: Suleman36
Post Number: 4138
ppi a600.2
Username: Adddisorder
West palm, Florida
Post Number: 2244
ppi>eD
also i think the directed a802 does 150x2@4
Username: Afroopuff
Post Number: 339
Alright I will look into those, thanks guys. Also, when running a 2 amp setup, do you all run a distribution block? or do you run 2 seperate power cables to the amps?
West palm, Florida
Post Number: 2245
you can use a distro block depending if the wire can hold the current your pulling if more then 1000rms get 1/0
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3667
i'd pick the new sundown audio one. 100x2 200x2.
Very nice brand
Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > 4 Ohm 2 channel 150-200 Watt per chan... [ « Previous ] [ Next » ]
