Home > Message Board > Car Audio > Multimedia Systems > Archive through February 06, 2007 > PS2 SLIM & BOSS DVD-2000 INSTALL????
Author Thread: PS2 SLIM & BOSS DVD-2000 INSTALL????
Username: Heidiltalburt
OKAY.. I HAVE A PS2 SLIM INSTALLED IN MY GLOVE BOX.. I HAVE AN INVERTER THAT PLUGS INTO LIGHTER ADAPTER.. I JUST WANT TO MAKE SURE I DO THINGS RIGHT.. I HEAR I CAN POWER THAT TO MY BATTERY.. SO DO I JUST CUT THE LIGHTER ADAPTER END AND USE THOSE WIRES? AND CAN I USE THE POWER WIRE THAT RUNS FROM BEHIND HEADUNIT THAT RUNS TO THE BATTERY THAT POWERS THE AMP? SAME ISSUE WITH THE DVD PLAYER.. ALL I GOT WITH THE DVD PLAYER IS 3 RCA CORDS AND AN AC/DC ADAPTER THAT PLUGS INTO THE BACK.. HAS A FUSE BOX ON IT.. DOESNT HAVE LIGHTER ADAPTER.. WHERE CAN I CONNECT THOSE WIRES? THANKS SO MUCH FOR THE HELP.. HEIDI
Username: Cadillacdb
Houston , TX
Post Number: 924
buy a power invertor and just hide it under the front seat or somthing and use it to plug everything into
http://www.walmart.com/catalog/product.do?product_id=3266877
Houston , TX
Post Number: 925
oh hold up.. i didnt read that all, i thought you were just asking how to use it in the car,, my bad
I HAVE AN INVERTER.. I DONT WANT EVERYTHING RUNNIN OFF MY CAR LIGHTER.. HOW DO I WIRE IT TO RUN OFF POWER? CAN I RUN IT OFF MY POWER WIRE THAT RUNS TO MY AMP? AND CONNECT IT BEHIND THE HEADUNIT?
Username: Tjmutlow
Post Number: 3337
cut the wires and run a wire from battery to a switch(power side) and ground the inverter to floor of car, then just plug the dvd player into the inverter.
CAN I RUN THE POWER STRAIGHT TO THE POWER WIRE THAT IS ATTACHED TO BATTERY?
Username: Tjmutlow
Post Number: 3338
if you use a distribution block or use a terminal at battery with multiple psots and run new wire.
Username: Dkchillin
Vermont
Post Number: 337
Just want to back up what Ty suggested. Run a new power wire from the battery (don't splice into any wires you have already run) to a switch, and then from the switch to your inverter and then ground the inverter.
Username: Psychedelic_feta
Montreal, Quebec
Post Number: 41
Get this inverter, it comes with everything you need including the kit you need to hardwire it to the battery. No cutting no nothing. All you have to do is attach it to a screw in your distribution block. and ground it near where you install it.
It also has a remote turn on wire. It's perfect for powering everything you mentionned you want to power.
Anything else?
Montreal, Quebec
Post Number: 42
http://caraudio.avdeals.com/powerinverters/mcpi300.htm
Home > Message Board > Car Audio > Multimedia Systems > Archive through February 06, 2007 > PS2 SLIM & BOSS DVD-2000 INSTALL???? [ « Previous ] [ Next » ]
