Thread: Are these Speakers Harmful to your HU? |
Bronze Member Username: Stangjason
Post Number: 12 Registered: Dec-06
| Posted on Tuesday, December 05, 2006 - 10:29 pm: |
These speakers are said to run at 2 ohm and I'm told a HU isn't supposed to run at 2 ohms though Crutchfield's advertisement claim it adds additional volume and punch to their sound without warning of potential damage. http://www.crutchfield.com/S-ORdt1XNGnRn/cgi-bin/ProdView.asp?search=gto&i=109GT O627 |
Silver Member Username: Cadillacdb
Houston ,
TX
Post Number: 922 Registered: Aug-05
| Posted on Wednesday, December 06, 2006 - 03:57 am: |
no one uses HU's to push comps these days man.. use a amp instead .. but what Hu is it eitherway ? |
Post Number: 13 Registered: Dec-06
| Posted on Wednesday, December 06, 2006 - 09:20 am: |
These speakes aren't components they are just rated 2 ohms. |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1037 Registered: Mar-04
| Posted on Wednesday, December 06, 2006 - 10:10 am: |
you have a point. There should be a warning. But they'd probably rather just sell them and hope the average HU user doesn't crank it all the time and the internal amp survives even though they're not designed to power 2 ohm loads. |
