Thread: Question about my rear speakers |
Bronze Member Username: Bryan333
Post Number: 31 Registered: Nov-06
| Posted on Tuesday, December 05, 2006 - 06:33 pm: |
I have 6.5" polk speakers in the back, and I am curious, how much bass should I have pushing through them? I have a bass equalizer on my deck wich allows me to put the bass from -6 (which makes it so theres minimal bass from the rear speakers, and mostly all of it from the subs)to 0 (pushes alot of bass out of the back speakers when the volume is on 20. When I put the volume on 25 with bass on -6 it sounds the same cuz the subs are pumping harder) all the way to +6 which sounds shitty cuz everythings distorted. What should I have it set too? I dont want to blow my back speakers that is why I am asking. |
Gold Member Username: Delsole
Post Number: 1147 Registered: Feb-05
| Posted on Tuesday, December 05, 2006 - 06:44 pm: |
what kind of HU you got. i know on mine i can set it so my speakers play jus the mids and highs while my sub play all the real bass. but if yours doesent do that i mean as long as you dont play the speakers while there so much bass coming out of them its sounds all distorted you should be good. i would keep it below 0. i keep all my trem/bass/mid at 0. for the most part its all however you like the way it sounds. |
Post Number: 32 Registered: Nov-06
| Posted on Tuesday, December 05, 2006 - 06:48 pm: |
Well I cant control mid on mine, I can control treble (which is on 0) and bass. When I have the bass below 0 I can turn the volume up louder and it would sound the same as if the bass were on 0 because the subs are playing the bass instead of the rear speakers evening it out. Also, with some songs when the bass is on 0, I cant hear parts of the beat. All I can hea r are the vocals and bass  |
Post Number: 33 Registered: Nov-06
| Posted on Tuesday, December 05, 2006 - 08:37 pm: |
bump |
New member Username: Zdubb
Post Number: 5 Registered: Dec-06
| Posted on Thursday, December 07, 2006 - 10:14 am: |
Hey bryan, not sure if you've already done this but you might just wanna play with your stereo. I'd turn your subs off first. The best thing to do might be to crank it to the highest volume you ever listen at, and start at +6 and then lower the bass till theres no distortion, and leave it there. Maybe even one notch down to be safe. |
Post Number: 45 Registered: Nov-06
| Posted on Friday, December 08, 2006 - 04:17 pm: |
Yeah, i've tried it. I might just get a whole new deck with new speakers controls |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 1422 Registered: Mar-06
| Posted on Saturday, December 09, 2006 - 10:51 pm: |
Are your rear speakers amped? |
Post Number: 50 Registered: Nov-06
| Posted on Sunday, December 10, 2006 - 12:30 am: |
no, theyre not |
Boston South,
MA
Post Number: 1428 Registered: Mar-06
| Posted on Monday, December 11, 2006 - 05:21 pm: |
Get a small amp on em. Something around 50-70 watts and it will liven them right up. If you get one with built in LP/HP settings you will have more control over the bass output. |
