Thread: ///The best components for sound quality\\ |
New member Username: As007
Post Number: 1 Registered: Dec-06
| Posted on Tuesday, December 05, 2006 - 11:44 am: |
I currently have the Focal K2P component set in my car, which is a 2001 330ci, they are being powered by a JL 300/4 amp. I want to upgrade to something better, but what?? I listen to a lot of trance so detail is what I am looking for. Price range is under $2,000. |
Bronze Member Username: Tc_skier
Post Number: 39 Registered: Oct-06
| Posted on Tuesday, December 05, 2006 - 12:13 pm: |
I'm assuming you have the 6.5" set of K2P's, and that you wanna stick with a 2 way set? Probably worth a look: http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4749 |
Post Number: 2 Registered: Dec-06
| Posted on Tuesday, December 05, 2006 - 01:01 pm: |
Also another question, say I was to keep the K2P's would going with a Zapco or Audison 2channel amp make them sound any different than they do now running off the JL 300/4? |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1038 Registered: Mar-04
| Posted on Wednesday, December 06, 2006 - 10:11 am: |
if the new amp is more powerful, and the speakers can make use of that power -- maybe. Otherwise, no. |
Gold Member Username: Delsole
Post Number: 1153 Registered: Feb-05
| Posted on Wednesday, December 06, 2006 - 03:01 pm: |
ebn though those amps are clealy better and put out more power i cant see a noticable difference in the way the speakers sound. mabe a little bit but only because of the extra power. |
