Home > Message Board > Car Audio > Head Units > Archive through December 26, 2006 > Putting a system in an impala--------...
Author Thread: Putting a system in an impala---------------
Username: Shutterleftopen
Columbus, Ohio
United states
Post Number: 155
i'm about to get a 2001 chevy impala and i had heard that it's a little complicated to hook up all new head unit and subs. is there anything i need to worry about? like external amp that needs hooked up or anything like that?
Username: Leew
XXXX!!WWWW, Yokosuka, ...
SPESNAZ. ...
Post Number: 1007
it's depend which oem radio system stay in! 2001 chevy impala got three radio system :
1.Base model.
2.With Amp.
3.CEO Model (separate cd player).
Username: Shawn_fleming
Gainesville, Florida
Post Number: 51
any you just changing out the head? or head and speakers, or head, speakers and new amplifer
Username: Leew
SPESNAZ. ...
Post Number: 1010
Head unit + set of new good component speakers + Amp + Sub + new wiring... It's costly but the best way to do it!
Username: Delsole
Post Number: 1091
well if theres a factory amp its prolly above the kick panel so you will have to make a jumper from the wire you pull out of the amp. the harness plugs into the wire you pull out of you amp.
Home > Message Board > Car Audio > Head Units > Archive through December 26, 2006 > Putting a system in an impala--------... [ « Previous ] [ Next » ]
