Home > Message Board > Car Audio > EQs and Crossovers > EQUALIZERS CONFUSE Me..
Author Thread: EQUALIZERS CONFUSE Me..
Username: Bigman3889
Post Number: 60
I am looking into buying an equalizer but idk what type i would need ..like witht he outputs and inputs and stuff.. i have a 4 channel amp amping my 2 fron door and 2 rear deck speakers...i also have another 2 channel amp amping my 2 subs...i want to use a equalizer for all three of these...possible? and what type should i look for
Relevant Product Info
Username: Van_man
Boston South, MA
Post Number: 1367
How much you looking to spend? They start around $50 and go way way up.
Check this one. It would work well and has the features you want.
Look at the second one down. the 5.1
http://www.performance-teknique.com/Equalizers.html
Post Number: 61
i want an equalizer because i want to control my frequencies better...which i guess is why everyone needs one lol but i dont wanna spend more than like 80$ but i have like some sort of fader sub out puts and sh!t like that in my HU..its the jensen vm9311ts
Username: Van_man
Boston South, MA
Post Number: 1377
http://electronics.search.ebay.com/car-eq_Signal-Processors_W0QQcatrefZC12QQfrom ZR8QQsacatZ79839QQsubmitsearchZSearch
Username: Tjmutlow
Post Number: 3316
spend a little more and get a audiocontrol three.1, do not waste your money on a cheap eq,
Fi Audio
BTL
Post Number: 7828
you can get an audiocontrol eqs. it has 3 inputs and 3 outputs. its perfect for what you want. only downside is that it mounts in the trunk so you pretty much have to set the eq and leave it.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > EQs and Crossovers > EQUALIZERS CONFUSE Me.. [ « Previous ] [ Next » ]
