Thread: 2 way 6x9 help please |
New member Username: Fran33
Post Number: 3 Registered: Jul-06
| Posted on Sunday, November 26, 2006 - 10:20 pm: |
ok i just bought 2 alpine 6x9's 275 watts, then i relized they said 2 way not 3-way, will i still hear the same music? I need sum explination. Do I need more speakers now too make it sound better??? I have a 760 wat pioner amp too hook them up too and i plan to get good subs. Please help me if you can. |
Silver Member Username: Johammbass
IRL
Post Number: 696 Registered: May-06
| Posted on Monday, November 27, 2006 - 03:57 am: |
You don't need 3way, because 2way is just fine. A lot of real high end component sets are 2way so you'll be OK. Don't worry, your 6x9's will sound just like 6x9's should sound, which is not nesseserily the thing that people go after , but you'll be fine |
Silver Member Username: Dsmith07
LaGrange,
NC
US oF A
Post Number: 265 Registered: Jun-06
| Posted on Tuesday, November 28, 2006 - 02:46 pm: |
if im not mistaken the 760 amp your referring to pushes 190 rms to each channel |
New member Username: Stangjason
Post Number: 8 Registered: Dec-06
| Posted on Tuesday, December 05, 2006 - 01:10 pm: |
I've actually read an article where they tested 6X9s and the author pretty much said that the two ways were almost always better than three ways and their was only one 3 way that they complimented for standing up to the 2 ways. |
Post Number: 9 Registered: Dec-06
| Posted on Tuesday, December 05, 2006 - 01:11 pm: |
Oh do a search on 6X9 and soundstream and I think you'll find the article. |
