Home > Message Board > Car Audio > Speakers > Archive through December 20, 2006 > CDT Audio M6 or CDT Audio HD-6
Author Thread: CDT Audio M6 or CDT Audio HD-6
Username: Mike11202
Sewell, NJ
US
Post Number: 8
These speakers say they have more bass than normal mid-ranges, and I do not want to hook up any subs. My speaker size is 6.5 or 5 1/4.
Are these mid-ranges right?
What tweeters should go along with them?
Or if neither what component set would suit my needs?
Thanks
Username: Suleman36
Post Number: 4129
They will work well for your application. I have a brand new set that i got thru CDT that i can offer you for $150 shipped.
Pair them with the DRT-25 tweeter and the 560 crossovers all by CDT.
They are mid range speakers that have more emphasis on bass which is perfect for what your after. They work well in a set so i whould recommend them.
I personally run the CDT HD62 set and like them.
Username: Alteraudiousa
Concord
Post Number: 1345
The M6 is geared for more midbass while the HD-6 has a more well rounded frequency response. Overall SQ i would go with the HD-6. I run the M6 in a 3way setup and love it. You said you have 6.5 and 5.25? Is that front and back? Or all up front?
Username: Mike11202
Sewell, NJ
US
Post Number: 9
I have 6" speakers all around, but do not want to waste money with the rears, just the components midbass and tweeters.
http://cgi.ebay.com/6-5-CDT-Audio-HD-62-Special-Pak-SALE-HD62-NEW_W0QQitemZ15006 3575852QQihZ005QQcategoryZ32819QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Those CDT HD-62's are only $279.99 because they do not come with grills. Should I buy them or is that a problem?
Home > Message Board > Car Audio > Speakers > Archive through December 20, 2006 > CDT Audio M6 or CDT Audio HD-6 [ « Previous ] [ Next » ]
