Home > Message Board > Car Audio > Speakers > Archive through December 20, 2006 > Tweeters
Author Thread: Tweeters
Username: Gwidas06
Post Number: 11
what if i conect tweeters with built in crosover to tweeter output on component set crosover???? I need to do that becouse my original component tweeters blew.. is there any tweeters that would play music very loud and clear and wouldn blow up
Username: Johammbass
IRL
Post Number: 697
Yes there are many good tweeters that will play the music loud and clear and will not blow up:-)
You just have to make sure that you are sending them clean signal from an amp and that they are crossed over properly. A few good examples of really good tweeters that play music very loud and very clear:
http://www.woofersetc.com/index.cfm?fuseaction=page.display&page_id=14&mfg_accou nt_ID=106&category_id=24
http://www.seaslotus.com/referencecomponents.asp
http://www.madisound.com/cgi-bin/index.cgi?cart_id=9838330.12218&pid=1142
...and others.
Many times people "blow" their tweeters because of clipped amplifier signal, you want to make sure that your amplifier is not being overdriven:-)
Home > Message Board > Car Audio > Speakers > Archive through December 20, 2006 > Tweeters [ « Previous ] [ Next » ]
