Thread: Interior Speakers |
Bronze Member Username: Qbenjamin
Florida
Post Number: 98 Registered: Nov-06
| Posted on Saturday, November 25, 2006 - 05:45 pm: |
I was looking at getting the JL A4300 for my interior speakers. I have a factory amp running to them, but I want to completely eliminate the bass. Am I to assume that if I do a direct hook-up from the stock speakers to the amp that they would be running at 4ohms? |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 2021 Registered: Jan-06
| Posted on Saturday, November 25, 2006 - 05:49 pm: |
well if its a 4ohm speaker then it will run at 4 ohm the amp doesnt determine ohm load! why compleatly eliminate bass and what freq. bass are you talking about anyway a crossover determines what freq. get to the speaker. |
Florida
Post Number: 99 Registered: Nov-06
| Posted on Saturday, November 25, 2006 - 06:02 pm: |
Woops, I actually have aftermarket speakers, all Orion interior's and components. |
