Thread: Trying to find 2 ohm 6.5 speakers |
Silver Member Username: Brynm
Prince Albert,
SK
Post Number: 254 Registered: Jul-05
| Posted on Saturday, November 25, 2006 - 09:41 am: |
As the title states, I'm looking at getting a Kicker ZX350.4 and would like some 2ohm speakers seeing as my cheap lightning audio's can't keep up without distorting badly. the amp is rated at 90w at 2ohms and unfortunately my budget is pretty low, about 150. so far I've only been able to find Infinity kappa 60.7cs or kappa62.7i on ebay. I'd like to find a solution that is either a set of coax's that can take some power or some components like the Digital designs ddc6.5 that allow you to mount the tweeter on the mid bass because I may not have the car to long and don't want to punch holes to mount the tweeters in it. |
Bronze Member Username: Longbluesquid
Post Number: 93 Registered: May-06
| Posted on Saturday, November 25, 2006 - 04:03 pm: |
i think Infinity kappa's are the only 2 ohm speakers ive seen |
Gold Member Username: Delsole
Post Number: 1031 Registered: Feb-05
| Posted on Saturday, November 25, 2006 - 05:49 pm: |
same here, atleast those are the only that are coming across my mind at this moment |
Post Number: 1032 Registered: Feb-05
| Posted on Saturday, November 25, 2006 - 05:53 pm: |
imma keep an eye out though |
Bronze Member Username: Help2
Post Number: 25 Registered: Dec-04
| Posted on Saturday, November 25, 2006 - 08:49 pm: |
image dynamics chameleons come in 2 ohm |
Silver Member Username: Johammbass
IRL
Post Number: 700 Registered: May-06
| Posted on Monday, November 27, 2006 - 04:11 am: |
Yep, Image Dynamics would be 2 ohm |
