Home > Message Board > Car Audio > Speakers > Archive through December 20, 2006 > Is this CDT set worth purchasing?
Author Thread: Is this CDT set worth purchasing?
Username: Deathshadowbal
Post Number: 12
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D320053412545&ssPageName=A DME:B:WNARL:US:12
If this is a good setup (looks like it is to me) I will be purchasing this; id like to hear some input before I lay down the cash though.
Should I get anything else?
Username: Delsole
Post Number: 1028
from what i hear yes but i think (dont hold it against me) you might be able to get a better deal. i think i might buy a couple of the mid woofers soon.
Username: Alteraudiousa
Concord
Post Number: 1343
the link doesn't work but PM me what it is and i'll tell you whether or not. remember no ebay acct unless its the CDT store has warranties and most will tell you on there, since i'm a dealer I hook people up on here. But PM me and i'll answer your questions.
Username: Pauldav
Post Number: 9
I have the HD-52's .... Mids sound good, had to replace the tweets - just couldn't get them to sound right
Home > Message Board > Car Audio > Speakers > Archive through December 20, 2006 > Is this CDT set worth purchasing? [ « Previous ] [ Next » ]
