Home > Message Board > Car Audio > Speakers > Archive through December 20, 2006 > Component speakers
Author Thread: Component speakers
Username: Baysideftb91
I was looking at the Kicker 6 1/2" Speakers (KS6.2) and the Polk 6-1/2" Component Speakers (db6500) which one do you all recommend and is there others that i should be concidering? The highest I can go price wise is probly about 250 maybe a little higher. thanks
Username: Johammbass
IRL
Post Number: 707
http://cgi.ebay.com/DLS-UP6-6-5-2-WAY-COMPONENT-SPEAKERS-ULTIMATE-NEW-UP-6_W0QQi temZ250054642168QQihZ015QQcategoryZ32819QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/NEW-DLS-ULTIMATE-UR5S-2-Way-Component-System-5-1-4_W0QQitemZ 190053858742QQihZ009QQcategoryZ32819QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5091
All of the above would be better than the stuff that you listed:-)
Username: Alteraudiousa
Concord
Post Number: 1350
i would get the HD-62 over the ES as the ES is going to be replaced and the HD has better frequency response over the ES. I do like the ES smooth high midrange though.
Home > Message Board > Car Audio > Speakers > Archive through December 20, 2006 > Component speakers [ « Previous ] [ Next » ]
