Thread: Replacing woofer from components set |
Bronze Member Username: Coreyl
Post Number: 15 Registered: Oct-06
| Posted on Wednesday, November 22, 2006 - 02:20 am: |
it appears that the woofers from my alpine spr-17ls components are damaged. I bought the set on ebay and its too late to return them. I'm thinking of replacing the woofers with a pair of poly 6.5. Will this work? Spr-17ls specs: 70 rms (350 peak) 87db poly 6.5 specs: 100rms 88db |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1341 Registered: Jan-06
| Posted on Wednesday, November 22, 2006 - 07:59 am: |
your crossover may change some aspects of the SQ since its made for a different woofer but should be ok. |
Silver Member Username: Johammbass
IRL
Post Number: 678 Registered: May-06
| Posted on Wednesday, November 22, 2006 - 09:57 am: |
Well, the chances are it will sound different, but you would have to know what to listen for. Just make sure that the woofer you are getting can do the freq range that it will be playing (make sure it doesn't roll off before the x-over point on the x-over) |
Post Number: 16 Registered: Oct-06
| Posted on Wednesday, November 22, 2006 - 12:39 pm: |
can you explain to me that the x-over does and how to set it? also how does dayton rs7 compare to the polys? Thanks. |
IRL
Post Number: 686 Registered: May-06
| Posted on Thursday, November 23, 2006 - 04:13 am: |
Just buy a new set, because you are deeper into woods than you think. It's not that easy to mix ant match if you want to achieve good results. Just get this: http://www.madisound.com/cgi-bin/index.cgi?cart_id=9838330.12218&pid=2129 It will sound better than your Alpine set. |
