Thread: Mid channel speaker Set up suggestions |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 1258 Registered: Mar-06
| Posted on Saturday, November 18, 2006 - 11:10 am: |
hi guys Im going to install a center channel. Most setups ive read about consist of a 4 or 6 inch driver (mid-range, or mid-bass?) flanked on each side by tweets. Wouldnt his create a wierd ohm load? (1.34) There are some mid channel prefabs out there. Sorry lost my focus.... So, any mid channel ideas? |
Boston South,
MA
Post Number: 1263 Registered: Mar-06
| Posted on Monday, November 20, 2006 - 05:41 pm: |
Silver Member Username: Delsole
Post Number: 979 Registered: Feb-05
| Posted on Monday, November 20, 2006 - 08:31 pm: |
if i was u i would say the h*ll with the mid channel and keep it simple |
Boston South,
MA
Post Number: 1285 Registered: Mar-06
| Posted on Tuesday, November 21, 2006 - 05:37 pm: |
Well joe, I feel the intensity in your Opionion, however I have a better idea. Anyone else have a complicated idea.. |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 1941 Registered: Jan-06
| Posted on Tuesday, November 21, 2006 - 05:51 pm: |
from what i hear the tweets wont make a difference in ohm load. i think the only point of a center channel is if you have a 5.1 processor |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1339 Registered: Jan-06
| Posted on Tuesday, November 21, 2006 - 06:18 pm: |
I would just buy a two crossover from Partsexpress and two 8ohm drivers and call it a a day. |
Boston South,
MA
Post Number: 1286 Registered: Mar-06
| Posted on Tuesday, November 21, 2006 - 08:08 pm: |
Yes Mat, I do have a 5.1 EQ, Hence the qestion. And Alter can you elaborate a little on that? 2 crossovers? 2 8ohm drivers? and this would be wired how? This is what Im looking to do. My Question is what kind of driver should I use? 2-full range? 2-mid range, And 1 tweet, Am looking at the Beyma AST 22, and a AST 05 Thanks. has/Is anyone else doing/done a 5.1 install? |
Concord
Post Number: 1340 Registered: Jan-06
| Posted on Tuesday, November 21, 2006 - 09:49 pm: |
All you need for a 5.1 setup is one center channel which will play preferably full range. I would suggest an 8ohm mid and 8ohm tweeter or some HT tweeters do have a pretty broad range( like q 2in tweeter) and use that. You will need a small amp to run them since most HT drivers need very little power compared to car speakers. Buy a crossover that does 8ohm speakers and wire it normally and there's you a center channel. |
Silver Member Username: Johammbass
IRL
Post Number: 680 Registered: May-06
| Posted on Wednesday, November 22, 2006 - 10:10 am: |
marc, pls let us know how it works out. I've never done a setup with a center ch. |
Concord
Post Number: 1342 Registered: Jan-06
| Posted on Wednesday, November 22, 2006 - 07:37 pm: |
centers are nice if you have a DVD playing or a 5.1 setup audio DVD. Other than that its crap. I've set one up for one of my friends car using a 3way component setup. We bought the drivers seperate but used a HD-6, EF-6Neo and Tw-25 and used the Satnet 30DT 3way crossover. The signal processor had an output for center channel for itself and we used a small 2ch amp bridged to run the setup. Worked quite nice for a center channel, the HD-6 was low in the dash where the trash/ash tray goes, the EF-6Neo and tweeter were up on top of the dash. He's been asking about sticking the M6 in there but I think that may be a little too much. |
