Thread: Need help |
Bronze Member Username: Oakland_az
Oakland,
Ca
Post Number: 26 Registered: Sep-06
| Posted on Wednesday, November 15, 2006 - 08:34 pm: |
ok guys i have 350-450 to work with. I want a pair of good 5 1/4 coaxial speaker(1 pair). 4 channel amp.and a 10" sub going for sq mostly. and if you can post websites where i can get them cheap that will be cool. THANKS! --i know this is the amp section but the other forum pages are not working. |
Oakland,
Ca
Post Number: 27 Registered: Sep-06
| Posted on Wednesday, November 15, 2006 - 08:37 pm: |
and i want to buy for online stores, not ebay but if i dont have a choice i might use it. and i dont have a account. so i have to use "Buy It Now" thing. THANKS |
Oakland,
Ca
Post Number: 29 Registered: Sep-06
| Posted on Wednesday, November 15, 2006 - 08:44 pm: |
please help, anyone??!?! |
Gold Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 1308 Registered: Oct-04
| Posted on Wednesday, November 15, 2006 - 08:50 pm: |
diamond audio D9 series are good components. CA&E reviewed some pioneer components recently and they gave them a good rating. but you want to spend a total of 450 on components, amp, and sub? you will deffinately want to run all of the speakers on the same amp to save you money. let me see what i can find |
Oakland,
Ca
Post Number: 31 Registered: Sep-06
| Posted on Wednesday, November 15, 2006 - 08:55 pm: |
hey i really don't want componets i rather stay coaxial because it's going in a limo, also because componets are a little expensive. and i might CTMIKE PGX400.1 for 150. i was thinking the Boston G2 10" good or no? Thanks for posting!! and i need a good 4 channel amp to run the mids/highs. |
Tulsa,
Ok
Usa
Post Number: 1309 Registered: Oct-04
| Posted on Wednesday, November 15, 2006 - 09:04 pm: |
sub: http://cgi.ebay.com/NEW-INFINITY-KAPPA-PERFECT-10-1-10-SUBWOOFER-1400-WATT_W0QQi temZ110056209594QQihZ001QQcategoryZ3291QQrdZ1QQcmdZViewItem amp: http://cgi.ebay.com/KICKER-ZX-ZX650-4-4-CHANNEL-650-WATT-AMPLIFIER-NEW-06_W0QQit emZ250049786861QQihZ015QQcategoryZ4950QQrdZ1QQcmdZViewItem Components: http://cgi.ebay.com/INFINITY-KAPPA-50-5CS-5-25-COMPONENT-SET-NEW-w-tweeter_W0QQi temZ250049786859QQihZ015QQcategoryZ32818QQssPageNameZWDVWQQrdZ1QQcmdZViewItem I don't recommend buying from indoaudio though, but this should give you a good starting point and should sound really good. you will still need stuff to install amp. (rca's, wires, etc.) |
Oakland,
Ca
Post Number: 32 Registered: Sep-06
| Posted on Wednesday, November 15, 2006 - 09:07 pm: |
hey lucas the links didnt work. |
Oakland,
Ca
Post Number: 33 Registered: Sep-06
| Posted on Wednesday, November 15, 2006 - 09:19 pm: |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 10130 Registered: Jul-05
| Posted on Wednesday, November 15, 2006 - 09:24 pm: |
PG Xenon 400.1 AA assasian Crystal Csc comps |
Tulsa,
Ok
Usa
Post Number: 1315 Registered: Oct-04
| Posted on Wednesday, November 15, 2006 - 09:31 pm: |
the setup that chauncey gave you is better, but he left out the amp for the components. here are the ebay item numbers: 110056209594 250049786861 250049786859 |
