Thread: Low current amp |
Silver Member Username: Hockeyknight
Post Number: 456 Registered: Apr-06
| Posted on Tuesday, November 14, 2006 - 12:29 pm: |
whats the rms i could push with a stock battery and a 200a alt???? i need a new alt anyways but i really dont wanna spend more $$$ on a battery...... also i dont really know much about the small specs of an amp so if someone could give me some info id appreciate it!! thanks |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3364 Registered: Dec-05
| Posted on Tuesday, November 14, 2006 - 12:52 pm: |
how many amperes your alt puts at idle?? |
Silver Member Username: Audioguy22
S.F.,
Cal.
Post Number: 318 Registered: Jul-05
| Posted on Tuesday, November 14, 2006 - 01:01 pm: |
If your running a class D at full power? about 2300 watts. |
Gold Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 1282 Registered: Oct-04
| Posted on Tuesday, November 14, 2006 - 07:33 pm: |
I wouldn't go that high with it. Probably more like 1500 watts class D at the most. You'll want headroom for an amp for the highs and you don't want to damage your stock battery. |
