Home > Message Board > Car Audio > Security Systems > Archive through November 24, 2006 > 2 way remote start alarm?
Author Thread: 2 way remote start alarm?
Username: Tcrowden
Ocean springs, Ms.
Post Number: 26
What is a good and cheap system for a 06 silverado?
Username: Teddy21
Ann Arbor, MI
Post Number: 271
dont buy cheap, it will break....
get a viper system from ebay and have a shop install it, im not sure the models but dont go cheap or you might run into some serious problems.
For instance, I have an AutoPage 2way remote start, sometimes it wont start and sometimes it does (with the remote). Recently it started making my car actuall not start when i use the key, it just doesnt turn over at all. This can be a real pain if your a long away from home and your car wont turn over.
Home > Message Board > Car Audio > Security Systems > Archive through November 24, 2006 > 2 way remote start alarm? [ « Previous ] [ Next » ]
