Thread: Bet you haven't heard of this amp problem |
New member Username: Ozsir2
Post Number: 1 Registered: Nov-06
| Posted on Monday, November 13, 2006 - 08:13 am: |
I have searched numerous forums and am wondering if anyone here knows what's going on. I replaced a new head unit to my system and reset the gain on my Alpine mrv-t402 (2 channel amp). Now when I turn on my stereo when it is at low volume there is crackle from the left speaker channel - which disappears when the volume is turned up...but also does not return once I turn volume back down. It is only after the system "has cooled down" when I notice crackle again. I have checked to make sure it's not the speakers (switching the L/R spkr outputs from the amps results in crackle in the right channel), and not the head unit (switching the RCA inputs to the amp - there is still crackle from the left channel). Turning the gain pot when music is playing does not affect the crackle so I don't think it is "dust" in the pot...but I do think it's got something to do with the amp's volume/output/sensitivity control. Any advice besides "take it to a professional" would be greatly appreciated. |
Gold Member Username: Carguy
Post Number: 5712 Registered: Nov-04
| Posted on Monday, November 13, 2006 - 08:53 am: |
Steve, try this test. Disconnect the right channel and power both left and right with the left channel on the amp. See if the crackling goes away. You could just have a bad left channel. How old is this amp? |
Silver Member Username: Johammbass
IRL
Post Number: 603 Registered: May-06
| Posted on Monday, November 13, 2006 - 09:16 am: |
...or see your doctor the next time it happens |
Gold Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 1277 Registered: Oct-04
| Posted on Monday, November 13, 2006 - 04:59 pm: |
have you tried a different set of rca's? |
Post Number: 2 Registered: Nov-06
| Posted on Tuesday, November 14, 2006 - 12:57 am: |
Thanks for the tip Isaac I'll try that and tell you what happens. Lucas I did actually install a "better" set of RCAs when I put in the new head unit. I suppose it may be worth swapping them again to see if there's a change...but as I said I tried swapping the rca channels around but that did not help so I don't think it's the rcas. |
New member Username: Sinful_systems70
Post Number: 6 Registered: Nov-06
| Posted on Tuesday, November 14, 2006 - 01:12 am: |
Did you run the RCA's next to any power wires? Can cause some noise in stereo sysems when RCA cables are run along the power wire for the amp. A good practice is to run power down one side of car and RCA's and remote down the other. Some would say to run remote wire with power wire but that wire doesnt carry enough current to make any noticable noise in your system. (but to play it safe run it down the power wire side of the car) The power wire side should be the side of the vehicle that the battery is on because you want the power wire to be as short as possible so you get the most amount of current possible to your amp. |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 1820 Registered: Jan-06
| Posted on Tuesday, November 14, 2006 - 04:45 pm: |
^^actually that will never happen unless you are using really crappy unshielded RCAs |
Bronze Member Username: Sinful_systems70
Post Number: 30 Registered: Nov-06
| Posted on Tuesday, November 14, 2006 - 04:55 pm: |
Yes, but I have no idea the quality of parts used in install. I was simply giving other alternative solutions to this problem. Very good point mat dope. Goes right with my quote "Don't go the cheap route!" |
West palm,
Florida
Post Number: 1822 Registered: Jan-06
| Posted on Tuesday, November 14, 2006 - 05:34 pm: |
quote:I did actually install a "better" set of RCAs when I put in the new head unit
Post Number: 40 Registered: Nov-06
| Posted on Tuesday, November 14, 2006 - 06:21 pm: |
Still tells me nothing about the overall quality, just that they are better than old ones. |
West palm,
Florida
Post Number: 1825 Registered: Jan-06
| Posted on Tuesday, November 14, 2006 - 06:27 pm: |
you got a point i took it that he had better RCAs as in better then agverage walmart ones |
Post Number: 41 Registered: Nov-06
| Posted on Tuesday, November 14, 2006 - 06:38 pm: |
I just wasn't sure so I gave a possible problem that could be looked into. If he knows they are shielded than you can rule out that problem. |
