Thread: 2 amps or 1 |
Silver Member Username: Hockeyknight
Post Number: 454 Registered: Apr-06
| Posted on Monday, November 13, 2006 - 02:26 am: |
hey im getting an fi Q and right now i have a alpine v-12 (600rms) should i just buy another alpine v-12 or for $250 or buy a memphis d1000.1 for 350??? |
Gold Member Username: Ctmike
Ct.
Post Number: 2340 Registered: Feb-06
| Posted on Monday, November 13, 2006 - 02:30 am: |
if you can afford it i'd get the memphis. you can always sell your alpine and save more. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3361 Registered: Dec-05
| Posted on Monday, November 13, 2006 - 06:48 pm: |
^^^^ But there's another thing: if you can get an alpine MRD 1005, it can push the FI Q properly. Is not the best to do and i agree with ctmike, get the memphis. |
New member Username: Sinful_systems70
Post Number: 2 Registered: Nov-06
| Posted on Tuesday, November 14, 2006 - 12:00 am: |
I suggest the Alpine PDX-1.1000. It pushes 1000 watts RMS from 1 to 4 ohms. Plus it only has (4)20A fuse rating which is low current draw to be easy on your electrical system. |
