Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > Does anyone know the RMS wattage for ...
Author Thread: Does anyone know the RMS wattage for a Kenwood KAC-9152D
Username: Teamdeboy1971
LAFOLLETTE, TN
CAMPBELL
Post Number: 8
I finally got my amp to stop blowing fuses on my 2-10"premier's 2504's, but Seems as though the subs are sounding like they should!! I have them in a full size Van that only has bucket seats in it! So, sounds like the subs are in a barrell!!!
thanks; Rob
Username: Ctmike
Ct.
Post Number: 2337
RMS Power: 500W x 1 @ 4 ohms
RMS Power: 900W x 1 @ 2 ohms
RMS Power: 900W x 1 at 1 ohms
RMS Power: 900W x 2 at 4 ohms (Dual Mono Drive)
LAFOLLETTE, TN
CAMPBELL
Post Number: 9
hey, this thing is supposed to be 1800watt dual mono drive!! Is there anyway to get 1800 out of it, or should I say, whats the best way to run this amp on my two 10 inch premier 2504's
Username: Ctmike
Ct.
Post Number: 2338
new amp. 1800w is never going to happen with that amp. always go off the rms, not the max. depending on the vc of the subs you'll need an amp that'll put out 1200wrms at either 1 or 2ohms'.
LAFOLLETTE, TN
CAMPBELL
Post Number: 15
WELL The only other amps I have are 2 OPTIDRIVE 2000D's that would be too much you think?
Username: Motomattic3
Post Number: 102
damn, there are a lot of people with those kenwood KAC-9152D all because they look at the max wattage. does nobody know that you look at rms,Plus its a ken-wood its as good as wood lol - thats so lame.
LAFOLLETTE, TN
CAMPBELL
Post Number: 25
What is a good 15" sub for around 320 bucks?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3360
FI Q, FI BTL; FI SSD, crystal comp X......
Username: N2audio
Lawrence, Ks
Post Number: 1008
use a 2000D at 1 ohm for your pioneers. Go easy on the gain, should work great.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3371
optidriven do you have AIM or MSN something like that???
My vibe 1800d is doing well, has more than a year, almost 2 and still is working. Never fixed and i'll use it until it blows
Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > Does anyone know the RMS wattage for ... [ « Previous ] [ Next » ]
