Home > Message Board > Car Audio > Navigation Systems > HELP with dual in dash dvd player
Author Thread: HELP with dual in dash dvd player
Username: Diggity99
St lous, Mo
i got a new dual in dash dvd player. I need help gettin it to play dvds while im driving. It has a parking brake ground also some kinda reverse wire that has to be tied into a light bulb or something. I had it working to play dvds by just grounding the parking break wire but everytime u turnt the unit off u have to re-ground the wire in order for it to work? If i hook a toggle switch up to it should that work or do i have to do something with that reverse wire? any input would be greatly appreciated.
Relevant Product Info
Username: Qbenjamin
Florida
Post Number: 39
toggle switch would work for you, but you have to remember to turn that switch off after your done using your navi function...
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Navigation Systems > HELP with dual in dash dvd player [ « Previous ] [ Next » ]
