Thread: Kenwood Amplifiers |
Bronze Member Username: Bobid77
Post Number: 30 Registered: Oct-06
| Posted on Sunday, November 12, 2006 - 01:04 am: |
Are the Kenwood Exceleon Series 4 channel and monoblock amps any good? I am thinking about the KAC-X542 4 channel and the mono KAC-X812D |
Gold Member Username: Ctmike
Ct.
Post Number: 2314 Registered: Feb-06
| Posted on Sunday, November 12, 2006 - 01:08 am: |
not the best but alot better than the regular kenwoods. ugly as hell to. you could get alot better, what are you planning to run and budget? |
Post Number: 32 Registered: Oct-06
| Posted on Sunday, November 12, 2006 - 01:30 am: |
I am planning to run 4 Infinty speakers 100-125 RMS at 2 ohm and an Alpine 15 inch sub anywhere from 800 to 900 RMS. id like to spend no more than $400 for 2 amps |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3354 Registered: Dec-05
| Posted on Sunday, November 12, 2006 - 07:59 am: |
for the type R, i suggest kicker zx 750.1 |
