Thread: Tweeters? |
Bronze Member Username: Thakidgame
Hialeah Gardens,
Florida
U.S.A.
Post Number: 56 Registered: Oct-06
| Posted on Saturday, November 11, 2006 - 05:23 pm: |
Since no one looks at the speakers section. I decided to post this here. I just got my subs intalled yesterday, and got some opinions from some of my friends. Everyone told me my mids were perfect and not to change them, but to get "Highs". Highs, I know mean tweeters. I know there preety cheap, I just have a couple question about them. Do I need a amp to power them? Or do they work right off the regular stock stereo? I would much rather install them to my my regular stock stereo, then to go and buy a amp specificly for them. To clarify, I listen to mostly Hip-Hop and Rap. |
Hialeah Gardens,
Florida
U.S.A.
Post Number: 57 Registered: Oct-06
| Posted on Saturday, November 11, 2006 - 05:27 pm: |
These look good, but I don't know if there good for me. http://www.crutchfield.com/S-YvAYQrUVoje/cgi-bin/ProdView.asp?g=430&tab=morephot os&pi=2&i=113KFCT207&display=XL#Tab |
New member Username: Kbjg
Eagan,
Mn
Us
Post Number: 2 Registered: Nov-06
| Posted on Saturday, November 11, 2006 - 05:56 pm: |
if your going to get tweeters go with polk audio they are the best and aslong as the max wattage is under 50 most decks will power them |
Hialeah Gardens,
Florida
U.S.A.
Post Number: 58 Registered: Oct-06
| Posted on Saturday, November 11, 2006 - 06:03 pm: |
So these http://www.crutchfield.com/S-mLCC7vws2Tm/cgi-bin/ProdView.asp?g=430&I=107DB1000 would work in with my stock stereo, and not sound like crap? |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 1786 Registered: Jan-06
| Posted on Saturday, November 11, 2006 - 06:28 pm: |
partsexpress.com has some nice tweets |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3352 Registered: Dec-05
| Posted on Sunday, November 12, 2006 - 12:03 am: |
try getting mild tweeters cuz there's nothing worse than a HARSH sounding tweeter, it drives you crazy man! hehe lol. |
Silver Member Username: Caraudio
Toronto,
Ontario
Post Number: 760 Registered: Sep-05
| Posted on Monday, November 13, 2006 - 08:05 pm: |
can u attack speaker wires to the speaker wires of the sub from the amp to power the speakers will they only ask the amp for as much power as they need or will the amp blow the speakers (say its a 800RMS x 1 at 2ohms amp) |
Bronze Member Username: Qbenjamin
Florida
Post Number: 42 Registered: Nov-06
| Posted on Monday, November 13, 2006 - 11:16 pm: |
the amp will blow the speakers. the amp will divide the power by the amount of inputs that are hooked up to each channel. A 500w rms subwoofer and a 50w rms spaker will = 550w rms, but that power will be sent to both inputs divided in half.....therefore the subwoofer will get 225w rms and so will the speaker (which will probably blow out on you). |
