Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > MONO amp question//
Author Thread: MONO amp question//
Username: Bigman3889
Post Number: 47
So on a mono amp ...if the specifications are 400 x1 channel at 2OHMS ....i wanna wire 2 kicker CVRs...and i wanna play them at 400RMS...so if i wire both subs at 4 ohms...and play them on a mono amp it makes it 2 ohms...which meens it plays 400RMS....correct? is it 400 watts each sub or is it gonna be 200 watts each sub? is there any downsides to this or what should i do?
Username: Ctmike
Ct.
Post Number: 2300
kinda lost on the middle part but on a 400wrms amp each sub would see 200w. depending on the vc of the subs you'll need 800wrms at either 1 or 2 ohms.
Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > MONO amp question// [ « Previous ] [ Next » ]
