Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > How much better are the Q's
Author Thread: How much better are the Q's
Username: Holt_champ
Htown, MI
Post Number: 172
are the ssd's comparable to the q's or are the q's way better?? i cant decide on which ones.
Htown, MI
Post Number: 173
and would it be ok to get a refubished amp from ebay??
Username: Adddisorder
West palm, Florida
Post Number: 1771
depends on what amp and it depends what you think is better. Q more SQ oriented. ssd more or a street beat sub
Username: Basshead86
Chrome Dip it & Ship i...
Post Number: 8466
well. that TOTALLY depends on application. the Q's are a SQL sub of sorts. the DO get louder than the SSD's, but not for watt. (from scott)the SSD's watt for watt are louder than the Q's...but when the SSD's run out of excursion, the Q's(excursion and extra power handling) get louder as an end result. if you want the most bump out of your ride with what amplifier you have. the SSD's are the way to go. if you can buy a beefy amp and want loud and good SQ..Q is your choice.:-)
hope that helps.
Htown, MI
Post Number: 175
thanks that helps alot
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3340
what's the brand of the refurbished amp? that's a factor too.
Htown, MI
Post Number: 195
kicker kx.2500.1
Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > How much better are the Q's [ « Previous ] [ Next » ]
