Thread: Odd Question, But PLEASE HELP |
Silver Member Username: Blazerboy
Post Number: 172 Registered: Jun-06
| Posted on Wednesday, November 08, 2006 - 10:17 pm: |
Hey guys, im not farmiliar with anything that sounds like this but my friend asked me to post this for him since he is away from a computer, so here it goes. what amp do i need for a stock radio with no amp out puts? Hopefully thats enough for an answer, any info would be great, links are good too! KO |
Gold Member Username: Logan__tille
Audioque USA
Post Number: 2361 Registered: Feb-06
| Posted on Wednesday, November 08, 2006 - 10:28 pm: |
You need a line output converter... |
Gold Member Username: Safe_cracker
Chicago,
IL
US
Post Number: 1999 Registered: Jan-06
| Posted on Wednesday, November 08, 2006 - 10:35 pm: |
You can hook any radio to any amplifier even without any preamp outs, FACT... Now how do you want to do it is up to you. You can either use some line out converters, the least expensive but yields the worse results, usually some amount of distortion due to the wire coils used to downgrade the voltage. My favorite would be to use a PAC adapter which uses a "vehicle specific" wire pigtail that plugs directly into the back of your factory headunit and to the PAC adapter itself. This actually will boost and filter the signal, it says 4V out but I measured almost 5.3V all the way up (40hz test tone) so it is safe to say that you can get a safe 4V+ out of it. There are also two sets out, front and rear also level adjustments on the PAC unit itself, great product. It costs a little but search e-bay, it is well worth it. This is the step I would take just before a new aftermarket head unit! Polo..  |
Silver Member Username: Jenifer_contreras
PIMP MemberŪ,
Yokosuka, Ka...
Post Number: 845 Registered: Jul-06
| Posted on Wednesday, November 08, 2006 - 10:36 pm: |
Click Here it's LIFT to L.O.K. |
Chicago,
IL
US
Post Number: 2011 Registered: Jan-06
| Posted on Thursday, November 09, 2006 - 12:51 am: |
You can hook any radio to any amplifier even without any preamp outs, FACT... Now how do you want to do it is up to you. You can either use some line out converters, the least expensive but yields the worse results, usually some amount of distortion due to the wire coils used to downgrade the voltage. My favorite would be to use a PAC adapter which uses a "vehicle specific" wire pigtail that plugs directly into the back of your factory headunit and to the PAC adapter itself. This actually will boost and filter the signal, it says 4V out but I measured almost 5.3V all the way up (40hz test tone) so it is safe to say that you can get a safe 4V+ out of it. There are also two sets out, front and rear also level adjustments on the PAC unit itself, great product. It costs a little but search e-bay, it is well worth it. This is the step I would take just before a new aftermarket head unit! Polo.. PS- The PAC adapter also gives you a remote out wire for turning the amp on.  |
