Thread: Possible with the Nine.4? |
Silver Member Username: Afroopuff
Post Number: 278 Registered: Jan-06
| Posted on Wednesday, November 08, 2006 - 08:25 pm: |
I want to hook up the CDT EF components (5 1/4 inches) to the Nine.4 electronic designs amp. Its a 4 channel amp that pushes 150 at 2x4OHM which is exactly what the EF components are. How do i do this? |
Gold Member Username: James1115
Ct
Post Number: 7365 Registered: Dec-04
| Posted on Wednesday, November 08, 2006 - 08:56 pm: |
you need to bridge the amp. Go on the website it should explain bridging on there. If not I will post something to helpo you out. |
Ct
Post Number: 7366 Registered: Dec-04
| Posted on Wednesday, November 08, 2006 - 08:57 pm: |
do you have the manual? it explains it in there. |
Gold Member Username: Crayola0
Wisconsin
Post Number: 1416 Registered: Jun-06
| Posted on Wednesday, November 08, 2006 - 09:01 pm: |
u mean elemental designs...right? |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3329 Registered: Dec-05
| Posted on Wednesday, November 08, 2006 - 09:39 pm: |
yeah... i was thinking the same jaymes. BTW nice amp and you should get a lil more output since the amp is measured at 12.5V |
Post Number: 279 Registered: Jan-06
| Posted on Wednesday, November 08, 2006 - 09:45 pm: |
yes jayme, sorry i was on the internet too long and looking at their website, i confused myself. No james, i dont see it on the webiste, and i have the nine.1 only at home. I just really like elemental designs so i wanted to stick with them for my components amp and the nine.4 seemed like the best one. If you could give me a lil over-view of bridging and it wasnt a pain that would be great. I am trying to learn about it a little at bcae1.com but its a lil confusing there. From what i gather, i think that you gain a little bit more power out of bridging, so maybe i should do the nine.2 instead. I really am just a lil confused on the bridging though. THanks  |
