Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > What should i do?
Author Thread: What should i do?
Username: Holt_champ
Htown, MI
Post Number: 130
i dont want to drill holes for terminals in my box. what can i use instead. i want to just drill a hole and run the wire through but i dont want to seal it because then it will be perminate. what should i do?
Username: Adddisorder
West palm, Florida
Post Number: 1727
put bolts in it and conncet the wire to that
Htown, MI
Post Number: 133
what kind of bolt should i get??
Htown, MI
Post Number: 138
and is it ok to put 16 gauge wire from the amp to the subs. what is the max that you should go with that??
Username: James1115
Ct
Post Number: 7359
how much power are you running? 16 should be fine, I reccomend 12 as a all around good wire for speaker connections but you should be able to get away with 16 if the run is short and you are not using thousands of watts.
Htown, MI
Post Number: 143
well i am almost sure that i am using 1500 watts (havent decided yet).
West palm, Florida
Post Number: 1741
id get bigger wire philip refer to www.the12volt.com for wiring sizes.
and for bolts marshall just uses regular ones from homedepot so steel but copper or gold plated would probly be a little better.
easyer to just run the wires threw the box and seal up the hole
Htown, MI
Post Number: 155
yea i might just do that.
Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > What should i do? [ « Previous ] [ Next » ]
