Thread: How long does it take to charge cap? |
Silver Member Username: Caraudio
Toronto,
Ontario
Post Number: 753 Registered: Sep-05
| Posted on Wednesday, November 08, 2006 - 08:53 am: |
1 Farad RockFord Fosgate Cap... im guessing i hooked it up i have my amp off... s0o0o im going to probably use it the entire day with the amp off would that be goood enuff? I hooked it up waited like 3min r so and i played it and the cap still didn make diff for the dimming of the lights it made maybe the SLIGHTEST diffence my human eyes couldnt tell soo give it the day to charge? |
Bronze Member Username: Moondogg1212
Post Number: 48 Registered: Aug-06
| Posted on Wednesday, November 08, 2006 - 09:07 am: |
it shouldnt take a day to charge a cap did you just hook it up to your power wire? you need a resistor to charge it! |
Silver Member Username: Johammbass
IRL
Post Number: 560 Registered: May-06
| Posted on Wednesday, November 08, 2006 - 09:11 am: |
Man, caps are soooooooo complicated Yellow top rulzzzzzzzzzz |
Toronto,
Ontario
Post Number: 754 Registered: Sep-05
| Posted on Wednesday, November 08, 2006 - 09:15 am: |
ohh that chip shiz dat came with it? and do i actually gota hook up ery wire to ery single thing sighh... ill go do that then |
Post Number: 49 Registered: Aug-06
| Posted on Wednesday, November 08, 2006 - 09:20 am: |
take the resistor hook it to your power wire hook the resistor to the cap. turn key on. or start car. leave the radio off. |
Silver Member Username: Audioguy22
S.F.,
Cal.
Post Number: 312 Registered: Jul-05
| Posted on Wednesday, November 08, 2006 - 11:56 am: |
should take <1 second, more with a resistor. To check the cap to see if its charged, use a 12 volt light bulb. |
