Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > Durable amp
Author Thread: Durable amp
Username: Luttrell31
Post Number: 40
This has probably been asked a hundred times but ill ask anyway, not looking to start an argument but what brand out there makes the most durable, longest lasting amp, with great quality and power. Opinions or experiences would be great. Longest lasting I have seen was a early 90s hifonic amp (lasted 14 years or so) The new one I got bxi 1206d lasted 2 months. Thanks in advance. (2 10" l5 solobarics is what i have.)
Username: 420alldaylong
Post Number: 728
Whats your budget for the amp? And what ohm are the kickers L5.
Post Number: 41
Around $2-300 can pay more 4ohm can be wired to 2 i believe.
Username: Basshead86
Chrome Dip it & Ship i...
Post Number: 8408
new hifonics is NOTHING like old.
check out Sundown Audio for some durable, powerful amps for a reasonable price for what you get.:-)
also, Crystal Mobile Sound has some nice ones, and so does Kicker. :-) ZX series is nice. also, US amps and Zapco. gettin pricey though....
Post Number: 42
Ive always liked kicker would the 600.1 be enough for those or would I need the 800.1
Username: Ctmike
Ct.
Post Number: 2285
those l5's are dual 4ohm. you'll need an amp that does the power at 1ohm.
Post Number: 729
Kicker doesn't make a 800.1 and the 600.1 is 2ohm stable you need 1 or 4ohm stable for those subs.
Post Number: 43
The instuctions said it could be wired from 4ohm to 2ohm. The 2ohm version can be wired to 1 ohm though.
Username: Ctmike
Ct.
Post Number: 2286
thats for one sub.
Post Number: 730
Get the Directed D2400 $268.35 from Techronics.com just make sure you keep the gain DOWN and you'll be fine.
Post Number: 731
And what kind of box are these Kickers in sealed or vented?
Post Number: 44
Sealed
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3312
durability= US AMPS. Get one of those entry level amps from that brand. You will like it.
Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > Durable amp [ « Previous ] [ Next » ]
