Thread: For those of you who know about amp placing......... |
Gold Member Username: Blainew
Diamonds in the back.
Post Number: 1796 Registered: Nov-05
| Posted on Wednesday, November 08, 2006 - 12:06 am: |
i got a new car....and its weird to put the amp on the seat back ..ir wouldnt really work....can i put my amp on the back of my sub box.... my amp is like raised 1/6 an inch above whatever u scrwew it onto....so would i be okay mounting it on my box?? the subs will be doin 1200 rms... |
Gold Member Username: Safe_cracker
Chicago,
IL
US
Post Number: 1986 Registered: Jan-06
| Posted on Wednesday, November 08, 2006 - 12:33 am: |
Tricky question, now here is a multiple viewpoint answer, lol. I myself would never mount an amp to a box because I have seen many an amp destroyed by box flex BUT if I really, really had to I would screw a secondary piece of 3/4" mdf to the side or the smallest accessable panel on the box and secure it to that. If you decide to do that then be sure to bolt everything down VERY VERY VERY well or you will make it extremely easy for people to jack yo sh!t! What about under your front seats? Polo..  |
Post Number: 1798 Registered: Nov-05
| Posted on Wednesday, November 08, 2006 - 12:36 am: |
the back seat situation is very weird..they are a new kind of seat...and dont connect to the side of the car....you can like put ur hand in the trunck, by going to the side of the seat...and the setas move around...the back seats are kinda like the front ones if u wanna think of it that way... i want the amp in the trunk, no doubt about it there is a cargo area all the way to the back, i just dont see how wires will get there...and i wanna keep the car in tact... i dno what to do |
Chicago,
IL
US
Post Number: 1987 Registered: Jan-06
| Posted on Wednesday, November 08, 2006 - 12:43 am: |
Pictures help  |
Gold Member Username: Ctmike
Ct.
Post Number: 2284 Registered: Feb-06
| Posted on Wednesday, November 08, 2006 - 12:46 am: |
couldn't you build a box that is slightly raised so you can have a slide out amp rack underneath it? |
Post Number: 1799 Registered: Nov-05
| Posted on Wednesday, November 08, 2006 - 12:49 am: |
i already have the box... i guess ill figure somethin out... |
Post Number: 1800 Registered: Nov-05
| Posted on Wednesday, November 08, 2006 - 12:53 am: |
http://cgi.ebay.com/ebaymotors/2006-RAV-4-LOW-RESERVE-30-PICS-VERY-CLEAN_W0QQite mZ220044348019QQihZ012QQcategoryZ31872QQssPageNameZWDVWQQrdZ1QQcmdZViewItem very good pics of trunk..... any ideas??? |
Gold Member Username: Redliner
Wilmington,
Ma
Post Number: 2853 Registered: Jun-05
| Posted on Wednesday, November 08, 2006 - 01:44 am: |
so why dont u just make a amp rack that will stand up next to the box. and if u really have to put it on the box try to get some foam type of stuff and build a amp rack then put it on the box and try to keep it separated by the foam but i would try anything b4 doing that |
