Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > What size fuse?
Author Thread: What size fuse?
Username: Crayola0
Wisconsin
Post Number: 1408
What size of inline fuse would i need for a ED Nine.1?
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 9911
as big as u can get
Username: Usask8er1
Appleton, Wisconsin
Post Number: 450
It should say on factory specs but I would say a 100amp fuse sounds about right
Username: Crayola0
Wisconsin
Post Number: 1409
well on the amp there are 4 30 amp fuses so would i need a 120 amp fuse but then the current draw can get up to 130 amps it said.
Username: Usask8er1
Appleton, Wisconsin
Post Number: 453
If it says 4 30 amp fuses then take back what I said about the 100, I think a 150 would do fine then.
Username: Crayola0
Wisconsin
Post Number: 1410
aight thanx
Username: Crayola0
Wisconsin
Post Number: 1411
wait if i but 1/0 ga wire for power wire can i use power wire for ground too?
Username: Usask8er1
Appleton, Wisconsin
Post Number: 456
yea just remember which is which if its all red. Maybe mark the ground or something
Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > What size fuse? [ « Previous ] [ Next » ]
