Thread: Which is better |
New member Username: Shelbycj
Shellbyville,
Kentucky
Usa
Post Number: 8 Registered: Oct-06
| Posted on Tuesday, November 07, 2006 - 10:22 pm: |
bandpass box or just a normal box |
Silver Member Username: Rvlacos
DD 3512 United States
Post Number: 370 Registered: Sep-06
| Posted on Tuesday, November 07, 2006 - 10:43 pm: |
depends on what ur goin for, me id never ger a bandpass! slot ported is my fav! |
Silver Member Username: Usask8er1
Appleton,
Wisconsin
Post Number: 448 Registered: Jun-05
| Posted on Tuesday, November 07, 2006 - 10:47 pm: |
If you want spl most people tend to go with slot ported, for sq most people tend to have sealed. I havent heard anything good from bandpass though. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3319 Registered: Dec-05
| Posted on Wednesday, November 08, 2006 - 05:46 pm: |
i'll say this. Bandpass is loud but, i really don't like it. It misses a lot of notes and it becomes a 1 note box. Plus is very hard to do a good working bandpass. I'd go with a normal box and depending your taste, you choose between sealed or ported. What subs r you going to use. Would be nice to know to give you a box recommendation |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 1738 Registered: Jan-06
| Posted on Wednesday, November 08, 2006 - 05:56 pm: |
iv heard good things about bandpass on caraudio.com a guy on there 80inches builds some really nice ones and everyone seems to love his sooo...get plans from him if your going to go bandpass personally just aero port it |
Post Number: 3324 Registered: Dec-05
| Posted on Wednesday, November 08, 2006 - 06:22 pm: |
^^^^^well... if the guy knows how to build them, then that should def, pound and sound good. |
Gold Member Username: James1115
Ct
Post Number: 7368 Registered: Dec-04
| Posted on Wednesday, November 08, 2006 - 09:02 pm: |
there are different types of bandpass encloaures, pre fab is garbage, sounds sloppy and muddy. $th order bandpass is nice so is 6th order if you know how to build them. They take a lot of exact calculations with no room for error. My buddy had 2 soundstream reference 12's in a 4th order bandpass and holy SH!T was it loud |
