Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > Pyramid amp problems
Author Thread: Pyramid amp problems
Username: Spandmh1
Post Number: 14
its a 1000 watt amp hooked up to 2 12" pioneer subs. the light went from green to red. dont know what caused it. anyone know?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3299
i'll give you a tip. Sell that pyramid.
What's the RMS and voice coil config on those subs. Tell us a budget
Username: Tjmutlow
Post Number: 3160
if you have that amp bridged, that is going to be your problem especially if those are single voice coil subs.
Username: 420alldaylong
Post Number: 735
I would say the problem is Pyramid they are cr@p.
Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > Pyramid amp problems [ « Previous ] [ Next » ]
