Thread: Hifonics BX1605d vs BXi1606d |
Silver Member Username: Brynm
Prince Albert,
SK
Post Number: 228 Registered: Jul-05
| Posted on Tuesday, November 07, 2006 - 05:14 pm: |
How much of a difference is there on the two amps,I've got the choice between the two and only $25 more fore the 1606.I know the ratings are the same but is there anithing different? |
Prince Albert,
SK
Post Number: 229 Registered: Jul-05
| Posted on Tuesday, November 07, 2006 - 05:15 pm: |
I need to spell check before I post |
Prince Albert,
SK
Post Number: 230 Registered: Jul-05
| Posted on Tuesday, November 07, 2006 - 05:16 pm: |
I need to spell check before I post, Do they both put out rated power? |
Silver Member Username: Rick_ross
Post Number: 596 Registered: May-06
| Posted on Tuesday, November 07, 2006 - 05:26 pm: |
the 2006 models are supposed to put out a little closer to the rated power but neither of them do put out there rated power they are both overrated |
Post Number: 598 Registered: May-06
Gold Member Username: Extrmndor3
Life is GOOD,
Ill
Us
Post Number: 2460 Registered: Feb-06
| Posted on Tuesday, November 07, 2006 - 05:44 pm: |
its the same board, juzz like 2 more caps and trasistor in the new model, will give you close to 20 watts more but they are the same the only thing is the heatsink |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3300 Registered: Dec-05
| Posted on Tuesday, November 07, 2006 - 07:21 pm: |
get the newer one if the difference is only 25$ |
