Thread: New install - engine noise in speakers |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 357 Registered: Nov-04
| Posted on Tuesday, November 07, 2006 - 12:33 pm: |
I know I've seen the answer to this before, just can't remember it. My friend just got a new install done with amps, subs, deck, speakers, whole 9 yards. When he accelerates or decelerates, he hears engine (kind of high pitched buzzing) noise coming out of the speakers. What would contribute to this? Thanks! |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3283 Registered: Dec-05
| Posted on Tuesday, November 07, 2006 - 12:44 pm: |
i had the same thing, i checked my grounds and RCAs and the sound went off |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 1699 Registered: Jan-06
| Posted on Tuesday, November 07, 2006 - 12:47 pm: |
grounds grounds grounds! 9x out of 10 |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 9674 Registered: Jul-05
| Posted on Tuesday, November 07, 2006 - 01:29 pm: |
faulty or shiddy rca also cause it ..... |
West palm,
Florida
Post Number: 1702 Registered: Jan-06
| Posted on Tuesday, November 07, 2006 - 02:08 pm: |
quote{faulty or shiddy rca also cause it .....} thats the other 1x out of 10 |
Bronze Member Username: Sinful_systems70
Post Number: 15 Registered: Nov-06
| Posted on Tuesday, November 14, 2006 - 11:34 am: |
I can be caused by a couple of other things. The RCA wire should not be run along side of the power wire or you will get noise in the system. Sinse you said the static changes with RPM,this is Backway Noise. This is noise introduced through the power and ground wires connected to your receiver. If you're hearing alternator whine (a whirring noise that varies with engine RPMs), you can install an alternator noise filter (like PAC's ANS-80) on the power line between the battery and the alternator to minimize the problem. You can also install a noise filter (American International's S15A (15-amp, 250-watt) or S25A (25-amp, 350-watt) filters, for example) on the receiver's power lead to cut down on signal pollution. It could also be from your spark plug wires. If you read up on spark plug wires,you will see that they can cause noise in your amps or subs. There are cretain sparkplug wires to stop the noise. Don't believe me? Read second paragraph on this page http://www.vitekperformance.com/shop/products_sparkplugwires.asp |
