Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > Testing an amp
Author Thread: Testing an amp
Username: Leonardotmnt
Post Number: 12
Is there a way to test an amp to see if it works without actually hooking it up? I'm thinking about ordering one but I won't be home to put it in my car until after the 15 day return policy is up. I was wondering if I'd be able to have my dad test it to see if it would work just in case I got a DOA and couldn't send it back. Thanks.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3265
yeah you can test it in your house, in a store.
Just get a battery and those stuffs
Post Number: 13
Do I need a car battery? And what else do I need?
Username: Carguy
Post Number: 5704
You'll need 12v source, rca cables, couple of speakers or sub, and a portable cd player.
Username: Saltyreefguy
Palmdale, Ca
Usa
you can bench test, need a power supply of descent amperage, a cheap radio with rca outputs, and some speaker of any kind. ready to test any amp or radio,eq's, etc.. hope that helps..
Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > Testing an amp [ « Previous ] [ Next » ]
