Thread: Lanzar 1600. Questions Please Help |
New member Username: Xtsee
Post Number: 1 Registered: Nov-06
| Posted on Sunday, November 05, 2006 - 06:48 pm: |
Ok so my lanzar 1600, everytime I turn it on it is fine until I turn up bass booster or volume. Right when i turn it on it is fine I have already replaced the Fuse in the power cord and the fuse in the amp. The Power light is lit up at first but when i turn up the volume or the bass booster it switches to the Protector LED, what does this mean? How do i fix it? I turned all the settings to low also. and this still happens. I am New to this so i have no clue what i am doing plz help. -Josh |
Gold Member Username: Killerzracing71
Fredericksburg,
Virginia
United states
Post Number: 1132 Registered: Aug-05
| Posted on Sunday, November 05, 2006 - 07:02 pm: |
your subs are prolly wired to low.....The ohms or impedence is lower than the amp can take.... how many subs and wut voice coil configuration are they....like dual 2 dual 4 or single 2 or single 4 |
Post Number: 2 Registered: Nov-06
| Posted on Sunday, November 05, 2006 - 07:03 pm: |
hmm.I'm not sure my friend help me hooks it up i know it is a 2 channel 1600 watt amp and my sub is a 12 infiniy kappa max 1400 watts and max 350rms |
Gold Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 1228 Registered: Oct-04
| Posted on Monday, November 06, 2006 - 12:29 am: |
I think that sub has dual voice coils. Try wiring each voice coil to a seperate channel on the amp. You probably have the amp bridged and the coils on the speaker in parallel. The other alternative would be to leave your amp bridged and put the voice coils in series. Look at this: http://www.bcae1.com/spkrmlti.htm |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3256 Registered: Dec-05
| Posted on Monday, November 06, 2006 - 10:22 am: |
get a good amp |
Tulsa,
Ok
Usa
Post Number: 1236 Registered: Oct-04
| Posted on Monday, November 06, 2006 - 12:46 pm: |
but juliob i thought that Lanzar were good amps. you are always telling us how great they are. |
Gold Member Username: Ctmike
Ct.
Post Number: 2252 Registered: Feb-06
| Posted on Monday, November 06, 2006 - 12:56 pm: |
thats a good one^^. |
Post Number: 3282 Registered: Dec-05
| Posted on Monday, November 06, 2006 - 07:11 pm: |
their optidrive line is good, STFU. When you're buying lanzar, you need to know which models are good, that's like power acoustik DB line. All models suck, except that line, the DB line is good. |
Tulsa,
Ok
Usa
Post Number: 1244 Registered: Oct-04
| Posted on Monday, November 06, 2006 - 09:12 pm: |
Lanzar is Lanzar. They SUCK. Period. |
Silver Member Username: 420alldaylong
Post Number: 718 Registered: Sep-06
| Posted on Monday, November 06, 2006 - 10:53 pm: |
Don't buy LANZAR or POWER ACOUSTIK products. Unless you like wasting your money. |
Post Number: 3286 Registered: Dec-05
| Posted on Tuesday, November 07, 2006 - 12:49 pm: |
well.... those are your opinions... i only see facts, you guys assume a lot, like lucas, he doesn't knows about kicker subs and he loves talking about them, but at least i know about some lanzar products and i can show the reality. |
Silver Member Username: Boomtank
Post Number: 104 Registered: Oct-06
| Posted on Tuesday, November 07, 2006 - 01:09 pm: |
the lanzar vibe series sucks |
Post Number: 3294 Registered: Dec-05
| Posted on Tuesday, November 07, 2006 - 01:18 pm: |
except the 1800D/1200D. Those put 1200w rms+ clean at 1 ohm. The 3100D is overrated, but puts 1700w rms for 300$ so is very decent. |
Bronze Member Username: Qbenjamin
Florida
Post Number: 20 Registered: Nov-06
| Posted on Tuesday, November 07, 2006 - 03:46 pm: |
Lanzar amps are trash juliob. Buying a lanzar amp is like buying TOMMY GEAR, instead of TOMMY HILFIGER....LOL @ u saying it is a good brand. All of their amps are intensely overrated and are of poor quality. Lucas I would recommend that you look into Hifonics or something like that if you are on a budget. Also those infinity subs that you have are worthless too. ANY MANUFACTURER THAT PUTS OUT A SUBS/AMP AND IT'S RMS ISN'T AT LEAST HALF OF THE SUBS/AMP, MAX POWER, STAY AWAY FROM THEIR PRODUCTS. I have had Lanzar and Power Acoustik when I first started getting into car audio, and I can personally tell you that they are of poor quality. IE (JL=10) (Power Acoustik=4.5) (Lanzar=3)!(Pyramid=2) (Pyle=1) |
Post Number: 3296 Registered: Dec-05
| Posted on Tuesday, November 07, 2006 - 04:53 pm: |
^^^^ you own MA AUDIO lol!! haha. Let me show a result from the amp i own, dumb4ss Lanzar Vibe 1200D Specs Price & Contact: $519; 800-765-7686; www.lanzar.com All measurements @ 14 volts unless otherwise specified. Frequency Response (4-ohm IHF Load 100 Hz Ref. crossover @ highest setting): +1.2 dB, –3 dB @ 288 Hz L/R channel error max deviation 20 Hz to 20 kHz: N/A Signal-to-Noise Ratio (Below Rated Output, “A” weighted): -82.4 dB Distortion at Rated Output @ 60 Hz: 0.8% @ 1200 watts Output Power (Resistive) (4 ohms @ 60 Hz to 1% THD+N): 469 watts @ 14 volts, 456 watts @ 12.8 volts, 305 watts @ 10.5 volts Output Power (Resistive) (2 ohms @ 60 Hz to 1% THD+N): 762 watts @ 14 volts, 748 watts @ 12.8 volts, 486 watts @ 10.5 watts Output Power (Resistive) (1 ohm @ 60 Hz to 1% THD+N): 1262 watts @ 14 volts, 1007 watts @ 12.8 volts, 696 watts @ 10.5volts Output Power (Reactive) {4-ohm IHF Load @ 60 Hz to 1% THD+N): 484 watts Output Power (Reactive) (2-ohm IHF Load @ 60 Hz to 1% THD+N): 893 watts Crosstalk @ rated output, 20 Hz to 20 kHz: N/A Damping Factor @ 100 Hz: 45 Voltage for Rated Output: 376 mV to 2.9 volts Idle Current Draw: 1 amp Current Draw @ 1/3 Maximum Power: 44.7 amps @ 421 watts Efficiency @ 1/3 Maximum Power: 67% Power-Up Noise: 41.4 dB SPL Power-Down Noise: 45.7dB SPL But you guys don't learn! |
Florida
Post Number: 23 Registered: Nov-06
| Posted on Tuesday, November 07, 2006 - 05:18 pm: |
Don't get it twisted JACKA$$. I only own the MA Audio becuase one of my Orion's blew just needed something to get by with. |
Florida
Post Number: 24 Registered: Nov-06
| Posted on Tuesday, November 07, 2006 - 05:20 pm: |
You are a real noob, if you only go by MANUFACTURER'S SPECS. The real test is a direct hook-up to compare power. |
Silver Member Username: Kaos15th
Post Number: 276 Registered: Mar-05
| Posted on Tuesday, November 07, 2006 - 06:32 pm: |
dont listen to juliob you should know by now,no one takes him seriously, he raises his post count by doing this ^^^^ his advice is useless i bet hes never heard anything better than lanzar, poor kid...... |
Post Number: 3302 Registered: Dec-05
| Posted on Tuesday, November 07, 2006 - 07:35 pm: |
hahaha lol! that benchtest you can find it on www.carsound.com YOu own MA audio cuz your orion blew. I bought a vibe 1800d cuz i found one for 145 wirh 1 year warranty and the sh1t is still alive and has more than a year. With avalanche, yeah i like raising my post account like you, you're just jealous right? ANd you're right, i've never heard a good system. Happy? now go to sleep, you don't know sh1t about CAR audio. Quintin to end this low end brand thread and you saying that i twisted the specs like lanzar is paying me to talk good about them, check the review here. Just read it, you don't need to agree with me, just a way for you to understand why i say they worth 145$. http://www.carsound.com/review_archive/amps/vibe1200d.html Avalanche, why don't you read it too??? maybe that way you learn something cuz obviously you don't read everything... Why do i say MA audio is bad. Check this out. They put their ratings at 14.4 volts, but those ratings don't reach their real rms ratings, they put like 1000w rms amp. 200x1 4 ohm 14.4 400.1 2 ohm 14.4 600x1 1 ohm 14.4 These numbers you can barely reach them if you have a good electrical system, with minor voltage drops. For example^^^^ and then they put: 400x1 4 ohm 17 volts 700x1 2 ohm 17 volts 1000x1 1 ohm 17 volts But these "real numbers" is hard or even impossible to reach with any electrical upgrade. Just too hard. That's the reason why i think MA AUDIO is bad. Just MO |
Gold Member Username: Nuck
Post Number: 4520 Registered: Dec-04
| Posted on Tuesday, November 07, 2006 - 08:03 pm: |
I need to wire my Harmon Kardon AVR685 into 5 channels, I need a connection for the sub...HELP? |
Tulsa,
Ok
Usa
Post Number: 1251 Registered: Oct-04
| Posted on Tuesday, November 07, 2006 - 09:03 pm: |
Juliob just because you watch porn0s doesnt mean that you know how to please a woman. Same situation with you and car audio. |
Tulsa,
Ok
Usa
Post Number: 1252 Registered: Oct-04
| Posted on Tuesday, November 07, 2006 - 09:20 pm: |
Quintin Benjamin I wasn't looking for an amp and I dont have those subs. Juliob if I pulled up next to you with my volume half way up you wouldn't even be able to hear your system with the volume all the way up. I think that pretty much sums it ALL up. So please just STFU and listen and learn. You Biiatch. |
Post Number: 3305 Registered: Dec-05
| Posted on Tuesday, November 07, 2006 - 09:55 pm: |
wow lucas you're a genious, i have a 800w rms system and you got a 2K rms. WOW is louder. BRO you're so stupid, of course yours is going to be louder, i don't like too much loudness, i'm not compiting and is very hard to drive with 1k rms bumping in your ride. Mirrors don't work. And lucas, it seems that you watch p0rn cuz you can't get laid and need to learn h0w to f*ck. Is not the same situation when you see a benchtest result, you can determine if the amp is good/bad. You can't judge the quality, but it really gives you an idea of what you're expecting. If carsound.com says the amp is good, then i believe them cuz that's their job. They're not going to talk thrash like you or me. A louder system doesn't means that you know more about car audio than me. check this out. What's the difference between a 1200w rms, like memphis for example and hifonics 1206d They should have the same output, but the difference is the quality. The hifonics is not bad, but the memphis is better. That happens with lanzar too, you can't compare the f*cking lanzar with a 400$ amp. But hell yeah you can compare it to any 145$ amp. lucas STFU you still haven't learned sh1t |
Silver Member Username: Riskyb
Post Number: 368 Registered: Feb-06
| Posted on Tuesday, November 07, 2006 - 11:03 pm: |
"but juliob i thought that Lanzar were good amps. you are always telling us how great they are." post of the day |
Gold Member Username: Crayola0
Wisconsin
Post Number: 1412 Registered: Jun-06
| Posted on Tuesday, November 07, 2006 - 11:18 pm: |
juliob gives great advice and has helped me out like most of the ppl with knowledge on this site...drivin, muddy, glasswolf....so on but lucus, i dont think ive ever seen u give advice to anyone since i have joined this forum....and ya lets compart 2000+ watts to 800 of course ur system is gunna be louder u fuckass....i bet if u were giving the same equipment in teh same car juliob's would be louder cuase he knows way more about car audio that ur b1tch azz does......END OF THREAD!!!! |
Tulsa,
Ok
Usa
Post Number: 1255 Registered: Oct-04
| Posted on Tuesday, November 07, 2006 - 11:23 pm: |
Did Juliob help you wire those 15" home speakers to your deck? Great!!! Another pubeless child thinks he knows what he is doing. |
Wisconsin
Post Number: 1413 Registered: Jun-06
| Posted on Tuesday, November 07, 2006 - 11:30 pm: |
ur such a fuckass how old are u 3 nice comback with the pubeless child.. dude just because ur 1 inch pubes are longer than ur d1ck doesnt mean u can insult other ppl for ur insecurities....and i have no money so stfu id rather have the sh1t ton of bass from those then no bass at all u p*ssy azz b1tch. |
Post Number: 725 Registered: Sep-06
| Posted on Wednesday, November 08, 2006 - 12:31 am: |
Plan and simple do not buy Lanzar even the Opti drive series. |
Post Number: 3313 Registered: Dec-05
| Posted on Wednesday, November 08, 2006 - 05:26 pm: |
well those are your opinions. I only say lanzar optidrive is good when you're tight. I'm always trying to help people here. This is a good example: "you need a 0.5 ohm stable amp and you're tight" Lanzar optidrive for 330$ puts 1962w rms at 0.5 ohms with 14.4 volts. Is that bad?? for the money, hell no! i'd go for it, and the quality is decent, you're not buying pyramid or sony. If you can afford better, get another brand. I bought a 1200-1400w rms amp for 145$and 1 year warranty. For the budget is awesome and has more than a year bumping my subs, so get over it lucas, you just try to annoy people all the time. Be happy with your 2000w rms and without your lanzar system. |
Tulsa,
Ok
Usa
Post Number: 1256 Registered: Oct-04
| Posted on Wednesday, November 08, 2006 - 11:18 pm: |
all i gotta say is jaymes and juliob you are nubs. you don't know what a real system is until you have one so STFU. |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1005 Registered: Mar-04
| Posted on Thursday, November 09, 2006 - 01:47 am: |
Lanzar's really blown it recently with the ratings on a lot of their lower priced stuff, which, understandably, seems to have turned a lot of people off. But STILL, for the COST, they put out plenty of power. You simply have to be intelligent enough to recognize you're getting what you PAY for, not what's printed in big bold numbers. Those are, as most of us know, just a method to attract newbie's and dumb people, which it seems this forum is full of. Lanzar's become a bandwagon bash brand, and that's fine, I guess, but of the 10 or so Lanzar's I've owned or currently own, I've had only one problem, and that was with the 1200D when it first hit the market. And the two optidrives I've been running for going on 4 yrs have performed perfectly. Lanzar optidrives are rock solid, and if you can get ahold of an older one - they are considered by many to be among the better amps ever sold. But Lanzar sucks...whatever you say
Post Number: 737 Registered: Sep-06
| Posted on Thursday, November 09, 2006 - 02:04 am: |
Repeat Lanzar Sucks Repeat Lanzar Sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks Repeat Lanzar sucks |
Post Number: 3332 Registered: Dec-05
| Posted on Thursday, November 09, 2006 - 05:12 am: |
what a problem... |
Silver Member Username: Tweeker
RE AUDIO
Post Number: 558 Registered: May-06
| Posted on Thursday, November 09, 2006 - 11:05 am: |
d@mn LMAO joey lol |
