Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > Can somebody Help me Plez
Author Thread: Can somebody Help me Plez
Username: In2deap
Post Number: 18
Does anybody no if These two go togetor...
http://www.circuitcity.com/ssm/Kicker-10-Subwoofer-Enclosure-Package-06TS10L52/s em/rpsm/oid/146353/catOid/-15481/rpem/ccd/productDetail.do
http://www.circuitcity.com/ssm/Kicker-Mono-Subwoofer-Amplifier-06ZX3001/sem/rpsm /oid/146771/catOid/-13095/rpem/ccd/productDetail.do
or
http://www.circuitcity.com/ssm/Kicker-2-Channel-Amplifier-ZX350-2/sem/rpsm/oid/1 56016/catOid/-13095/rpem/ccd/productDetail.do
And Do i need to Buy this to
http://www.circuitcity.com/ssm/Tsunami-Amplifier-Power-Kit-AMP350AGU/sem/rpsm/oi d/71671/rpem/ccd/productDetail.do
Username: Adddisorder
West palm, Florida
Post Number: 1683
to be compleatly honest that stuff is basically crap and way over priced.
what is your budget for subs and amp and i take it your basically looking for spl
Username: In2deap
Post Number: 19
its ok/um for both of them togetor maby 600 to 700///
or am i suppose to pay more
West palm, Florida
Post Number: 1688
kicker zx750.1 (unless you want to upgrade your alt.)
and maybe fi Q or ssd from ficaraudio.com
or an arsenal from ascendantaudio.com
also look at a DD 2500 from ddaudio.com
Username: In2deap
Post Number: 20
What about the amp
Username: In2deap
Post Number: 21
also i dont want to buy a real big 1 and make the car heavier/its a 81 trans am, fiberglass body kit/
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3245
get an alpine type R Dual 4 ohm and an alpine mrd 605
Username: In2deap
Post Number: 22
Whats the Best matched for an Kicker( a amp. and subwoffer) thats good..
Username: Dustin3
Tigard, OR
U.S.
Post Number: 4051
why do you want a kicker sub? i would definently look somewhere else... whats ur budget? cuz i can pick you out a great sub and a "kicker" amp is you want
Username: Killerzracing71
Fredericksburg, Virginia
United states
Post Number: 1133
prolly cuz ery1 he knows rusn kicker....LOL....but mike dont go wit them get those other companys hes talking about....
u will fell so good when u blow there best buy systems out of the water when u pull up with stuff they have never heard of
Username: Holt_champ
Htown, MI
Post Number: 86
could 2 15" ssd's be louder that 2 15 L7's with a zx1500.1 amp?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3262
well phillp that's hard cuz you're underpowering those l7s but they have more cone area. I'd pick those FI all the way, cuz l7s tend to blow a lot, their cones are not so good and you might have to recone them like 10 times lol!
Phillp, when you get a good system, you're going to come here and thank all the guys who helped you, cuz seriously, your sh1t is going to bump if you get some FIs or AA arsenals
Username: In2deap
Post Number: 23
Hahaha i want something like under 800/i want something that i can buy from like a store and not online like bestbuy or circuitcity /idk y
,thks
West palm, Florida
Post Number: 1748
well mike buying on the internet is the cheapest route and if you buy from places with a good rep. you wont have any problems
an and damn an 81 trans am i want one so bad i love those beasts put up a couple pics of the body and engine
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3328
mike, try with onlinecarstereo.com or wooferetc.com those are really nice places to buy with free shipping and warranties.
Username: In2deap
Post Number: 24
Thks and also how much watts whould i be needing in that type of a car,like for an amp. and sub.///thks
Username: Nyyfan13
VA
Post Number: 688
u wanna match the rms (continuous power) of your sub with the rms rating of you amp.
so for example, if you sub does 500 watts(w) rms at 2 ohms and its a single voice coil (SVC) sub then you need an amp that does about 500 w rms at 2 ohms.
if you sub is ,for example, a 2 ohm dual voice coil (DVC) sub, then you want an amp that does the subs rms at 1 ohms or at 4 ohms.
make sense or help at all?
Username: In2deap
Post Number: 25
umm kinda wat about sumthing like this///http://www.circuitcity.com/ssm/Kicker-10-Subwoofer-Enclosure-Package-06TS10L52/s em/rpsm/oid/146353/catOid/-15481/rpem/ccd/productDetail.do
and
Username: Nyyfan13
VA
Post Number: 690
im just curious, why only circuit city or best buy?
u can get a lot better stuff out there for a lot cheaper.
for 600-700 you could get a nice sub and nice amp. you dont have to use ebay if you dont want to either. you can use legit websites, like the ones liste above if you want.
Username: In2deap
Post Number: 26
o ok /cuz i dont want to order some thing and when it comes and it doesnt fit in the ca r and stuuf or its super heavy/idk
Username: Nyyfan13
VA
Post Number: 692
alrite man, i def recommend to use the internet.
what size sub you loooking for? 10, 12, 15, 18?
Username: Nyyfan13
VA
Post Number: 693
and how much power do u want? just for daily use to add some more bump to your ride?
Username: In2deap
Post Number: 28
ya
Username: Nyyfan13
VA
Post Number: 696
alrite, there are many choices then.
12" DD1012 or 10"DD1010
ddaudio.com
12" DD2512 or 10" DD2510
ddaudio.com
12" Fi SSD or 10" Fi SSD
ficaraudio.com
12" FI X or 10" Fi X
ficaraudio.com
12" ascendent audio aresenal or 10" ascendent audio aresenal
ascendantaudio.com
take a look and tell me what you think
if you want you can post your question in the subwoofer section and get some more opinions
by the way, all these subs are less then $250 and is alot better than the kicker. and the weight, their all less then 25lbs.
Username: In2deap
Post Number: 29
um idk it really doesnt matter/i just want sumthing to be kinda loud or loud/but idk
Username: Nyyfan13
VA
Post Number: 697
the ssd, aresenal and 2512 will all be plenty loud for you, i beleive. they will def be louder and sound better and last longer than the kicker.
post it in the subwoofer section and you will prob see some of those subs listed above again and some new ones that i cant think of.
Username: In2deap
Post Number: 30
so just wondering how much wats whould i be needing
Username: Nyyfan13
VA
Post Number: 699
the ssd is rated at 800rms but can handle up to about 1000.
the arsenal is rated at 700rms and takes a lil more but not too much
the 2512 rated at about 600 i believe but can handle 900 and still want more.
in my opinion, your best bet would be either an aresenal and give it about 600-700 watts or maybe a 2512 and give it about 600-700 watts.
ur not gonna wanna go over about 800rms tho cause then you mite have to upgrade your alternator on you car.
Username: In2deap
Post Number: 31
o ok/if a sub. is 900 how much whould i want the amp. at
Username: Nyyfan13
VA
Post Number: 700
yea want a sub that does 900 wrms at the right ohm amount.
Username: Rick_ross
Post Number: 615
i have a kicker zx300.1 for sale in perfect condition for $80 shipped if u want it
Username: 420alldaylong
Post Number: 740
Mike
Woofersetc.com
Kicker Solo Baric L5 10" Dual 4ohm $159.99
Kicker ZX400.1 $169.99
Build your Box for $30-$35
Username: In2deap
Post Number: 32
Jw is it easy to install a head unit/does anybody no the steps or anything/thks for all of ur guys help
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3347
joey, a l5 is not a good sub for a SQL setup, i'd rather get a CVX.
Home > Message Board > Car Audio > Amplifiers > Archive through November 15, 2006 > Can somebody Help me Plez [ « Previous ] [ Next » ]
