Home > Message Board > Car Audio > Head Units > Archive through October 22, 2006 > Alpine CDA-9855 Bass Problem
Author Thread: Alpine CDA-9855 Bass Problem
Username: Dudeman5000
Hey everyone,
Im having a slight problem adjusting the bass to the subwoofers on this deck. I have 2 jl audio 10 inch subs in a jl powerwedge enclosure. I have a jl audio e2150 150watt amp. The Subwoofers hit well and loud....but heres the problem.....theres literally no bottom end bass at all compared to my old head unit. I can feel the subs hitting but on certain songs it's just all vibration and no bottom end bass. Can anyone help me out with this issue. Thank you!
Username: Shawn_s
Post Number: 7
What are you settings at (EQ, Xover, and Bass boost (the one you get when you press the vol. knob))?
My settings are , Subwoofer is all the way up. With the Range on 0. Cross over is all the way up. Defeat is off. EQ is set at USER 1 (which i made) I used the graphic EQ instead of parametric. I haven't messed with the settings to much. Today my friend tighend the screws on my sub box, and also tweaked the amplifier in my trunk with a little bit more gain. Although I don't think this will fix the problem.
Home > Message Board > Car Audio > Head Units > Archive through October 22, 2006 > Alpine CDA-9855 Bass Problem [ « Previous ] [ Next » ]
