Home > Message Board > Car Audio > Head Units > Archive through October 22, 2006 > Cda-9835 installing
Author Thread: Cda-9835 installing
Username: Schwic79
Post Number: 27
Im installing this cd player in my girlfriends car, i got her stock radio out, 1996 ford taurus and their are two plug ins for that radio and one for the apline so im assuming do i just cut the wires to those two plug ins and start splicing wires and match up by the colors? thanks
Username: Makmillion
MN
United States
Post Number: 1147
NO!!!
Get the proper wiring harness adaptor at your local walmart/circuit city/best buy/ultimate electronics or anyother store that carries car audio and video.. don't cut the harnesses unless you have to!
At walmart the harness adaptor runs less than 8 dollars..
Username: Tjmutlow
Post Number: 2963
you can not get that at walmart, that is the football looking kit with ac controls and relocation harness. get it off ebay....
MN
United States
Post Number: 1158
Didn't check on the year, but the older ones don't require those items.. my bad.
Username: Tjmutlow
Post Number: 2966
yeah, easy installs ended in 95
MN
United States
Post Number: 1159
woops.. you can,however, get those kits at the other stores I've listed.. not cheap, though.. and usually special order but sometimes in stock.
Username: Schwic79
Post Number: 28
i have the faceplate with the heater controls, ect. i just need to find a wireing harness now
Username: Tjmutlow
Post Number: 2976
that comes only with the kit you buy, it is a relocation harness...
Username: Audioguy22
S.F., Cal.
Post Number: 266
You might try the local stealership, sometime they're cheap on some stuff.
Username: Schwic79
Post Number: 29
problem solved thanks for all help
Home > Message Board > Car Audio > Head Units > Archive through October 22, 2006 > Cda-9835 installing [ « Previous ] [ Next » ]
