Home > Message Board > Car Audio > Security Systems > Archive through November 24, 2006 > Clifford concept 40 : no response fro...
Author Thread: Clifford concept 40 : no response from channel 2 3 4
Username: Zupafunk
Hi there, first, sorry for my english.
I got an mazda miata with a clifford concept 40 installed. Everything is working perfectly ( alarm, door lock, windows closure) except some channels :
Headlights / Trunk pop is absolutely not working. The clifford brain is supposed to send a negative voltage on the gray/blue wire for enabling trunk pop. This same brain is supposed to send positive voltage on the pink wire (a timer) but nothing happens.
I've tested all the wires (directly on the brain plug), it's just like if I weren't pressing on the remote keys.
Of course I've tested the remote, and all buttons work perfectly ( for button 2 & 4, I can test that with sensor adjustement).
Is there any particular instructions in order to say to the brain "hey I've some accessories, so If I press on the button, make your job...THANKS"
(of course I already tried to speak to the brain, but no result =) )
Little note : silent arm disarm doesn't work (button 2), and it's a standard function...
The only way to see that the buttons 2,3,4 are working is when I press shift twice (for remote sensibility adjust)
Thanks a lot for your help
Sunny greetings from France
Zupafunk
Home > Message Board > Car Audio > Security Systems > Archive through November 24, 2006 > Clifford concept 40 : no response fro... [ « Previous ] [ Next » ]
