Home > Message Board > Car Audio > Amplifiers > Archive through May 14, 2004 > Should I bypass the amp?
Author Thread: Should I bypass the amp?
Username: Flounders
I recently put a new 4X40 watt deck in my 96 Thunderbird. Since then, I have been having problems with the speakers' volume. Setting the volume at level three (of thirty) it is sufficiently loud. I have also had to change the balance to +10 on the left side so that left and right are equal. Should i just bypass the factory amp to get rid of this problem? Or is it something more serious? If i need to bypass the amp, are there any suggestions?
Username: J_capone
Chicago, IL
Post Number: 23
well it sounds like you have a faulty factory amp
you should have to change the balance that drastic to +10 on the left to make it equal..
take it back and looked at
what brand deck is it?, might be a cheap brand..
Username: J_capone
Chicago, IL
Post Number: 26
oops..i didnt mean factory amp
i mean..it sounds like you have a disfunctional head unit..
if its a pioneer...they have a nack of having problems like that..
either way get it looked at from where u bought it
i have had a ton of pioneer head units and never had that problem.
did you check to make sure you hooked it up right.
Username: Cadillacstyle0
Post Number: 30
sounds like bad wiring or a bad head unit
Username: Flounders
It is a Rockford Fosgate FF9120 head unit. I can check the wiring and the head unit, but the fact that volume three, with thirty being the top, was pretty loud, I had thought that the problem could have been in the factory amp.
Username: Newb
Post Number: 136
i thought some of the better head units were alpine and pioneer?
Username: Its_bacon12
Post Number: 558
they are,
rockford doesnt make the best hu's, they are much better in the amp section
Username: J_capone
Chicago, IL
Post Number: 27
well ive known alot of people that had a broken down pioneer head unit, prolly installed wrong or something..
but thats all pioneer is good for...stay away from pioneer subs or amps..i dont think they make amps...but they're subs are cheap junk
hot garbage
well james what do you think about your junk system i would have pioneer ANY day over you junk.
Username: J_capone
Chicago, IL
Post Number: 31
you'll always be a hater lil guy
Home > Message Board > Car Audio > Amplifiers > Archive through May 14, 2004 > Should I bypass the amp? [ « Previous ] [ Next » ]
