Home > Message Board > Car Audio > Head Units > Archive through October 22, 2006 > Dual CD770 Faceplate Movement
Author Thread: Dual CD770 Faceplate Movement
Username: Aeopav
Post Number: 14
I have a problem with the faceplate movement on this Dual CD770 I just installed in my Jeep. When I first powered it on and went to open the faceplate to install a CD, the faceplate jammed against the dash. I had it installed too deep so when the faceplate tipped out and began to move, it jammed against the dash. I turned the unit off and manually moved the faceplate back to it's stowed position and removed the unit to adjust the installed depth. I now cannot get the faceplate to move. Is theere some way of resetting the faceplate to get it to move again? I have no manual for this unit.
Thanks,
Mark
Home > Message Board > Car Audio > Head Units > Archive through October 22, 2006 > Dual CD770 Faceplate Movement [ « Previous ] [ Next » ]
