Home > Message Board > Car Audio > Multimedia Systems > Archive through November 18, 2006 > Hook up lcd screen
Author Thread: Hook up lcd screen
Username: Volfenhagking1600
Post Number: 8
how would a person go by hooking one of these up to the back of your cd player?
Username: Tjmutlow
Post Number: 2923
you don't. how are you going to watch anything. needs a dvd player. then the screen should have a video in and the dvd audio goes to the cd player if it has and Aux in feature on it.
Post Number: 12
one of my buddys has a screen hooked up to his deck and it shows a list of all his songs and he can even play music vids.
Username: Tjmutlow
Post Number: 2924
it depends on the deck, what deck do you have?
Username: Tjmutlow
Post Number: 2925
and what deck does he have?
Post Number: 28
http://www.cardomain.com/item/JENVM9311TS
this is my deck
Username: Makmillion
MN
United States
Post Number: 1117
plug it into the video ouput on your head unit... should be yellow in color, if color coded.
Home > Message Board > Car Audio > Multimedia Systems > Archive through November 18, 2006 > Hook up lcd screen [ « Previous ] [ Next » ]
