Home > Message Board > Car Audio > Amplifiers > Archive through May 14, 2004 > Amp Settings Help
Author Thread: Amp Settings Help
Username: J_capone
Chicago, IL
Post Number: 17
ok..
i just wired my subs using the reference wiring wizard @ http://www.rockfordfosgate.com/rftech/wiringwizard.asp and i used this one
-> http://www.rockfordfosgate.com/rftech/wiringwizard/2_4ohmSVC_2ohm.gif
my amp is 2 ohms stable..so no problem with this
but i noticed my amp has some settings
a little x-over feature..
that has a switch for HI - FULL - LO
right now its on lo...but what would be the best to use considering how i have everything wired..
i also have lil options to fine tune the HI, LO, and shift phase in dbs..
and the basic gain, bass boost which i already have configured just right..
anyone make sense of this mumble jumble i just wrote?
let me know..
Clay
if it sounds good like it is then i would leave it.
Home > Message Board > Car Audio > Amplifiers > Archive through May 14, 2004 > Amp Settings Help [ « Previous ] [ Next » ]
