Thread: Thinking about putting in a new alarm system. |
New member Username: Lickwid
PA
Post Number: 9 Registered: May-04
| Posted on Monday, May 10, 2004 - 11:54 pm: |
I want to put in a new Alarm system in my 96 integra gsr. Basically i want to know if its going to be an easy task or if it would be worth having it done pro. I have my eye on a Commando FM-870 2 way LCD Alarm. I want to have it set up so that my windows will roll up when i activate the alarm, would also like to know if its possible to do that with Moonroof & trunk Sensor, also make trunk accessable by button rls on remote. I want to have it so if anyone bumps into the car i'll be notified on the pager, windows are tampered with, door handle is yanked on. And will this be able to work with existing alarm for door locks. I saw there is a bypass for factory alarms. Not sure if I would need one for my car. So those are my questions any input would be appreciated. |
JeremyC Unregistered guest |
| Posted on Monday, June 28, 2004 - 07:15 pm: |
LOOK INTO CLIFFORD ALARMS. ME AND MY FATHER HAVE HAD ONE IN EVERY VEHICAL WE HAVE OWNED, AND NEVER HAD A PROBLEM. AS FOR THE OPTIONS YOU WANT, CLIFFORD HAS YOU COVERED IN EVERY DEPARTMENT. CHECK OUT THEIR WEB SITE FOR MORE INFO. http://www.clifford.com |
