Home > Message Board > Car Audio > Amplifiers > Archive through May 14, 2004 > On a slight budget
Author Thread: On a slight budget
Username: Vwbug1971
Warren, Nj
Post Number: 8
I'm on a slight budget but i want quality sound thats also loud. I was originally thinking one jl 10w6 but the adire shiva seem to be good by the way you guys talk about them. Would i be better off getting two adire shiva's instead. If so what amp could i match to this?
Dirk
If I was you I would get two shivas and a JBL 600.1 amp.
True. The Shiva in my opinion is better than the W6 and on par with the W7.
Home > Message Board > Car Audio > Amplifiers > Archive through May 14, 2004 > On a slight budget [ « Previous ] [ Next » ]
